SAFC II HI & LO...
COHIBAGSX
38
Feb 27, 2004
MANAGUA, Central America
On the Apexi SAFC II HI & LO setting means? Its not RPM since you have the same RPM setting for both. I was already informed that the +- means you add or decrease the air the ECU see's therefore it adds or decrease fuel @ that given RPM. I just need a little more understanding on what exactly is HI & LO. Is it in a high/ low gears? Thanks! :dsm:
throttle position. depending on where you set TH. Pt. say you set TH. Lo to 30% then 30% of pedal travel and under would work off of your low settings exclusively, and if you set TH. Hi Pt. to 80% anything over 80% pedal travel would work off hi tables only. In between the safc averages the LO and Hi settings. 30% Lo and 80% Hi are what most recommend for unhacked MAFS. On a hacked 1G maf Ive heard 60% and 80% will give better part throttle driveability since your LO setting will be way high to richen up at idle and part throttle. THis lets you use low tables at 60% of throttle to maintain better cruise and idle characteristics.
