SAFC help
Shipe12
43
Oct 11, 2008
Sinking Spring, Pennsylvania
Hi i recently installed a SAFC on my 99 eclipse GST. I have it set on karman mode and everything seems to be running fine. I am just not getting a airflow reading and the throttle says 100% all the time. Any suggestions?
also i was wondering how far apart the 2 ground wires should be mine are only a few inches.
Thanks!
mine is about the same 2 inches apart, as for the problem you are having double check the wiring and make sure everything is connected correctly and taped off to prevent shorting anything out
I have everything wired correctly. It could only be a part/settings issue. Ive triple checked the wiring. The wires i am using for airflow is pink and orange and pink being the one going to the ecu.
