Safc 2 need help to get car running
geiturbo
Sep 27, 2004
toronto,
on the weekend i installed a safc2 on my 93 laser. the car does not have much done to it. it has 2 1/2 downpipe and 3 exhaust from the cat back, manual boost controller set to 16 pounds and a 2g mas. i took the spark plugs out and saw that it was running lean. if anybody could help me with some tuning #'s for the safc2 it would be very appreciated. i just want to know that the car will be safe to drive without blowing it up, and no i do not have a logger yet so i could not do any pulls to check everything. TIA
without a logger leave your numbers at zero, plus do you have an upgraded fuel pump? If not i wouldn't boost past 14psi. You really can't use the afc until you get a fuel pump and injectors.
