2G ?s About outlander Brakes
ManticSHadow
234
7
Oct 3, 2009
Bentonville, Arkansas
On my 95 gsx if I bought the outlander rotors and calipers and brackets will they also bolt on to the rear or is it just a front brake upgrade? I just want to know, cause this and locating a new turbo back exhaust are the last pieces to get my project together and the car back on the road.
You don't need to buy calipers though since you already have the same dual piston calipers the outlanders use.
Truth. You just need the brackets and rotors.
And check your wheel fitment. I have the 2g 5 spokes and had to grind a considerable amount off the caliper to get it to clear the rim when using the outlander brackets.
Most of the Mitsubishi Parts are interchangeable, you try finding some in the junk yard or local auto parts and oem dealers as well.
