Rusted bolts
Status
Not open for further replies.
TALONHEARTBREAK
Feb 22, 2004
middletown, New York
Hey this is my problem .I have got a 97 talon and im puttin headers on.The last two bolts that i need to take off are under the car and attach to the cat.I have used pb blaster for like the 4 days spraying it every day in some hope that the bolts will loosen.Is there any like tip or trick out there that im missing?People have told me sook it in straight vinger,use a torch and heat it up and than try.Im using the viniger thing know it only removed a little rust but to no provale there still stuck.what can i do? :cry: :cry: :cry: :cry:
i would have to second the torch idea, you need it hot though, get those things red hot, then try to break them loose. i think the cat has studs, so you have to be carful. but the best bet would be to remove the studs and replace with a high quality bolt so this dosent happen again.
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
