Rust
Mychel23
92
Jan 18, 2010
South Bend, Indiana
How much does it normally cost to get the strut tower rust fixed? Just trying to get a general idea on how much others paid
i can get some
See if this works
LOL thats nothing compared to mine man, mine actually had holes. paid 200 for driver side and 80 for pass side.
Basically he cut the piece which was rusted and a little more and cut out another piece of strong metal and welded it in place :thumb:
Damn... and i thought mine was bad. I thought i was looking at like $500+ to fix all this
Take a flat head screwdriver and poke around the rust, if it goes through you need to cut the towers off and weld up donors. If it doesn't poke through the metal is strong and you can sand it down and repaint. I'm in Illinois so rust is an issue so most people around here remove the surface rust and spray down a heavy coat of bed liner. Cost all depends on the shop so I can't help you there.
Yeah mine is from Michigan. I have it on the underside too but i wanna start by fixing this first. Im afraid the underside is going to be the really costly part. But basically fix the rust on the towers and spray the shit out of the underside of the tower and call it good?
just pay attention with the undercoating. if it doesn't get a good contact it could leave a air bubble underneath which can get moister under it and rot out. I've seen it a few times
