Runs on starting fluid
lar426
Dec 30, 2008
Alexandria, Virginia
This is the car 1996 Eclipse 420a non turbo manual trans just a little over 100k. The previous owner and some of his friends thought they could change the head gasket (wrong). So I picked it up after they had taken the head off and could not get it back together. The car is now all back together with all the pieces they broke or missed up having been repaired or replaced. I went to start it, turned the key, fuel pump runs it has fuel to the rail, cranks well has good compression, it has spark, it runs fine on starting fluid but appears that it has no injector pulse (no fuel from the injectors). Am I missing something? I need some help from the experts.
Thanks Larry
mine was camshaft sensor...just check wiring.crank sensor will also cause this...if crank sensor just "dies" then it wont store a code either.i pulled my inectors and tryed starting engine and nth..i messed with crank sensor and it shoot fuel everywhere...worth a check
I changed the cam sensor, the crank sensor I even changed the magnet on the cam, it is still the same no fuel from the injectors. I runs fine as long as it has starting fluid to keep it running. It revs up idles everything it should do just not on the injectors. I checked the wiring no broken or frayed wires no blown fuses. When It is idling on starting fluid there is no clicking heard from the injectors I also noticed it will not run at all, with out the cam or crank sensor or the ASD relay plugged in, so it appears they are all working, at least to me. I don't want to get a PCM unless I know it will fix the problem This thing is driving me nuts I need some more help/advice what am I missing?
The 420 powered eclipses have a tsb for the cam and crank sensors and new connectors. The old style is round so if your connectors on the crank or cam sensor are round then they need upgraded to the new sensor and connector. You may be able to get this aftermarket but I would go directly to the dealer and get it as this is a very common problem and will have the parts in stock and can look up the exact part numbers per the tsb. The other thing is make sure that the fuel pump relay which is on the ds part of the fire wall, first one on the left, is not corroted internally. This is very very common. I have had many with bad relays. goodluck
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
