Bostedquest
- 1,235
- 5
- Oct 18, 2004
Zeigler (Boon Docks),
Illinois
Ok... I got the engine and the car seperately.
So no, the car did not run when I got it.
I finally got the CORRECT stuff from summit to finish the oil lines.
Put in the fuel, top off the oil. Crank without spark to build the oil pressure like you should.
Put the plugs in and it fires right up but runs like absolute crap. Forget an idle, feathering the gas constantly to keep it running.
Take it to 3K to get something steady (Then hear the sweet whine of the T4) and it was music to my ears. Not to mention I blow off some pipes that I did not have clamped.
But none the less, the longest I got it to run was about 4-5 minutes. The rest is 30 sec -1:20.
But now I cannot get it to start for anything.
While keeping the RPMs down, I had steady vacuum. -17.
I know I need to adjust the timing some, but it is close right now.
Inspection reveals no loose connections, or hose leaks (mainly because I removed just about all of them) So I am going to swap TB's tomarrow to check over the ISC.
So where can I start here? I was grinning ear to ear just to hear the thing run, even as crappy as it was running, it was SOMETHING after 18 months of waiting.
