GSTdude06
- 481
- 11
- Oct 29, 2005
Mesquite,
Texas
Since my 7bolt engine took a crap ive went on a buying spree and I think im running out of things to buy and im kinda sad. The list of what ive got is below and if anyone wouldnt mind Id like to know what they think should be added. My goal is around 400-450whp without NOS.
Thanks for those who help!
The list
Update as of August 21, 2006
Ram Air Intake
Greddy BOV
Greddy Hard Piping
14B Turbo
Walbro 255 Fuel Pump
Fuel Pressure Reg. set at 43psi
Fuel Pump Rewire
Thermal Exhaust 3" piping 5" tip
Test Pipe
1g TB 60mm
650cc
FMIC w/ short route piping
DSMlink
9lbs Flywheel
COP Setup
Poly Motor Mounts
Sheet Metal Intake Manifold
Stage 4 Clutch
3" Downpipe
38mm External Wastegate
Tubular Manifold
6bolt Engine Swap
Metal Head Gasket
ARP Studs
Manley Springs
Manley Exhaust Valves
Thats all ive gotten so far buy in the next week I plan on buying....
Garrett T3/T4 50trim turbo a/r .70
O2 Housing for it
and Water/Meth injection
Is there anything else I should look into buying to reach my goal??
and yes I did look at the tech guide...
Thanks!
The list
Ram Air Intake
Greddy BOV
Greddy Hard Piping
14B Turbo
Fuel Pump Rewire
Test Pipe
1g TB 60mm
650cc
DSMlink
9lbs Flywheel
COP Setup
Poly Motor Mounts
Stage 4 Clutch
3" Downpipe
Tubular Manifold
6bolt Engine Swap
Metal Head Gasket
ARP Studs
Manley Springs
O2 Housing for it
Thanks!
