Running extremely rich (smog rich)
codywv
84
Apr 5, 2012
parkersburg, West Virginia
Hello, I have read up on other posts about running extremely rich, but I just can't seem to figure exactly why it is. I have done a full 6 bolt swap and the only aftermarket parts that are on it is short route FMIC, lightened flywheel, 2g fuel rail, stock injectors, stock turbo, greddy BOV, stage 2 clutch, and 3" exhaust STRAIGHT BACK.... I'm not sure if the straight pipe is what the main problem is, but I would like to cut down on the fuel some.... I dont have a wideband O2 yet.... Need to buy one asap...
Any ideas?? Someone said turning up the boost may lean the fuel out.. Will that work?
i recently replaced my intake, it was leaking a large amount of air. I have not done a full boost leak test yet
ok, Thank you for the help. I will finish my boost leak tester this week and test it.
