RadDsm
- 1,679
- 25
- Apr 28, 2008
Eugene,
Oregon
I'm in a predicament right now. I've got 3 cranks, and they all need a bit of machine work, one only needs to be cut .010.
Has anyone ran a cut crank? I'm looking to make 450whp on this motor, and I don't want the crank to be the weak part or failing after the last 13 months of saving to build the car.
If someone could give me some insight about it, I'd greatly appreciate it because I'm tired of buying cranks, and this is the only thing holding me back from getting everything put back together.
. . . Doesn't mean full .03" of nitriding would have helped you. Like I said several have pushed the cut crank to 700+ whp. . . Examples referenced in my link. Even the factory recomends cutting the crank if there's scores. I linked proof. There's too many variables in your situation to prove it was the fact it was cut alone that caused the issue. If everything was done right and you have proof the crank measured within spec (at certain points), then machining was done wrong. Like I said you need a proven machinist who knows what they are doing.
h fvck Im a retard. . .
