Rubber exhaust hanger tips..
AL92
933
4
Dec 12, 2003
regina, SK, Canada
What is the easiest way to get my new exhaust to go into those rubber hanger things?
I don't want to rip them with screwdriver what do you guys use??
WD40 will clean the rust up from the old hangers and act like a lubricant. Spray them good and wipe with a rag first to clean away excess rust and crap. Then spray them again just before you slip them through.
I used wd 40 and they slipped in easy as pie..no hammer no pry bar needed.:D
I got them off the old brackets and onto my apexi brackets also without much problem. So really it was very easy.
Oh anyone know what size plug I would need to fill my rear o2 sensor hole. my old rear o2 sensor has pretty messed up threads and would rather just use a plug until get a wideband 02.Is it same as a drain plug ?
Thanks guys.
