rs turbo
I don't see why not really. My main concern was the exhaust manifold if it was the 63pattern or the 420a
This is straight from their website...
Hahn Racecraft - Automotive Turbosystems
You can use it with stock internals if you run it the way they recommend and don't get boost hungry. Makes a GREAT kit to start with and replace things as you go. It is a bit pricey but like I said, its a great "here is everything, put it on" kit.
And if you order it from Hahn, its a bit cheaper!(thats a first :p)
Under about 8 psi tops, is pretty much the limit for stock internals..The hahn kit there is rated at 5 psi..But It is the whole kit..But for twice the price of the link I posted..
