bstaley
- 73
- 3
- Jun 2, 2011
Okemos,
Michigan
95 gst had a blown head gasket, bad clutch so pulled the motor replaced:
Head gasket
Water pump
Timing components
Alternator
Starter
Timing belt
Clutch kit
Got it to run but only on 2 cylinders. So i replaced:
Coils
Power transistor unit
Nope. Took it to a shop, 5 months later they replaced the Crank Sensor. Still didn't run right so i got it back. Figured I'd try the last resort replaced:
Cam Angle Sensor
WORKED! Ran OK adjusted clutch, still needs work. Now here's the problem. While idling if you rev it up to about 4k to 5k and let off the gas it dies. After restart idle is very rough like 200rpm and rich. Also on a 5 mile round trip started running really rich and wouldn't run right over 2k rpm. Limped it the rest of the way and then tried to start it up when i got it home again. Wouldn't stay running. Figured it was the Coolant Temp Sensor so replaced:
Coolant Temp Sensor
PVC
Plugs
Unhooked the battery reset the ecu. Just for reference no CEL's after CAS replace. It idled very well,very responsive, still dying when rev to 4k to 5k and let off. So after it died started it up and same symptoms idles around 200rpm very rough. Also there is a small o2 housing to down-pipe leak.
Help Please.
Head gasket
Water pump
Timing components
Alternator
Starter
Timing belt
Clutch kit
Coils
Cam Angle Sensor
Coolant Temp Sensor
PVC
Plugs
Help Please.
