Rotor help plz
Status
Not open for further replies.
girlsare3viI
43
Sep 13, 2004
hungtinton, West Virginia
Hey i need new rotor's anyone know a good site for crosed / slotted rotors without paying $150 for the front two. Also i have a 94 talon 1.8. What is the braking system abs? Cause a few sites i saw had brakes for 93+ some abs and some non? anyhelp would be great cause mine are shoot. Also would it be bad to put the front rotors slotted/crossed drilled and the back two just replacement oem?
I wouldn't suggest buying cheap rotors, especially crossdrilled and slotted rotors.
As for ABS, that's Anti-Lock braking system. Does your car have Anti-lock brakes?
And also, it will be fine if you put slotted/crossdrilled up front, and leave rears stock,. as the fronts do basically all the braking.
Yeah, you don't need to make a whole new thread about the same thing when your old one is 5 threads down
http://www.dsmtuners.com/forums/showthread.php?t=173804
Status
