Rotating a Turbo housing?
boosted99_420
307
Apr 26, 2010
Fort Carson, Colorado
Ok i have a new lil project i am working on now and will have to rotate my turbo housing around. to face the other way. Ill just go aheead and say its for a 4g63 swap into a Starion. I have read about it on Project Zero G and just cant seem to understand it. I need it to face like a Evo 4-9 turbo is pretty much how i need it to look and work. Any help would be apriciated and if i cant get it rotated or find a cheap used Evo 4-9 turbo ill just make a Manifold for it.
Just buy an Evo VIII 16G and the Evo VIII manifold. You can get both parts for less than $250 in good used condition because there is absolutely zero demand.
The manifold will bolt directly to any 4G63 head and will place the turbo properly for good clearance to the firewall. The turbo's inlet will be at the front of the car and the turbine housing will exit toward the firewall.
While you're at it, pick up an Evo VIII stock intake manifold....the placement of the throttle body will be on the front of the engine as well.
