Rota Torques 35mm offset
ETalon95
232
Sep 11, 2004
Whitehall, Pennsylvania
I can get a really good deal on Rota Torque wheels, but they are 17.8 with a +35mm offset. I am currently running a 215/50/17 tire will they work?
Someone has to know if 17.8 wheels with a 35mm offset will work on my car with 215/50/17 tires!
I used to have 17/7.5 with 35mm and 225/45 tires and the back rubbed a little with 1.5 inches lowered with the allignment corrected. With 215 tire you should be fine/vere close to the lip.
Well, my car is lowered roughly about 1.4 inches. I can also get a 17.8 with a 48mm offset, if I add some spacers I Proly could get it down to a 43mm? Isn't there a guide that tells you what sizes your car is elgible for?
