rod bearing issue
smoney3
Apr 11, 2011
louisville, Colorado
i have a bad rod knock i have a new crankshaft but need evrythng else before i pull da engine..will just a re-ring kit have everything i need to finaaly get dis job done? some help from yall wud be nice
Exactly, what he said^^^
Also, we have all been warned please spell properly this isn't ebonics class.!
You do realize that you spun a bearing and sent bearing material throughout the entire engine. I have seen lifters in the head destroyed from bearing material making it into the head. It also severly scuffed the journals in the head. The oil pump also expirenced excessive scuffing throughout the internal housing. The proper way to fix a spun rod bearing is the pull the engine and go through every procedure to clean the extremely contaminated engine. You must take apart the bottom end and the head and hot tank and clean every oil galley. If you don't your in for another spun bearing.
