Rocker Arm order?
No, rockers are interchangeable, they are not specific like cam caps
Alright, thanks. I couldnt find anything that exactly said it, so i thought i would ask. Lastly, what about my lifters...i tried to push them down and they dont move. Is that normal?
You need to bleed them thoroughly before reinstalling them. They'll tick for a good 10 min after startup, just let it idle for awhile and it'll quiet down.
I like to use the back of a small drill bit instead of wire, but this will give you a rough idea
YouTube - Bleeding 4g63 lifters
Hey guys, so im installing my rocker arms again on the car and bout ready to put the cams on.
I noticed there are numbers on the rocker arms now. Is there any certain order they go on?
Technically the manual says to keep them in order, however I don't believe it makes a difference either.
Ok, thanks guys, im just getting everything ready and "re installed" today, timing will be done tomorrow, and hopefully getting this thing done.
And thanks for the video, i found the write up and read about bleeding them already.
I just need to get these done and then the cams can do in and be ready to set the timing.
