mattdev
- 349
- 2
- Jul 15, 2006
San Antonio,
Texas
Coolant temp is running hot (due to thermostat, which is going to be changed) about 210-230max. Last WOT 3rd gear pull I had 7* timing, while my a/f ratio was under 11:1.
Running 22psi w/ 93 octane should be pretty simple. What makes me ask, is my underhood temps are extremely high (I'm guessing due to my high coolant/engine temps), would this cause me to knock/pull timing due to the all around high temps?
Thanks!!
Thanks!!
