[RESOLVED] Radiator fan HELP....IM stumped
ryno
205
4
Nov 1, 2005
boise, Idaho
Ok so out of nowhere my passenger side radiator fan decided to stop working.(the main fan)
And I cannot find the reason. It just randomly stopped. And now my car is running off my AC side fan(that i have hooked up to a manual switch) but tis not getting the job done too good.
Things I have checked:
Relays are good
Fuse is good
Fan is still good ### i tested by hooking the wires straigh to my battery and it still came on
Im throwing no CEL, therefore i wouldnt think a sesnor(engine coolant temp) would be bad.
What are my other options, i cant stand this fan not working, it is 100' here in ID, and my car aint liking it too much.
Is there a possibility the sensor is bad and not throwing a code? And would this effect the fan not turning on?
thanks
I would check the fan wires to be sure they are not broken anyplace. If they are good and you know the fuses & relays are good I would go with a new coolant temp sensor.
I used the wires that came straight off the fan, but i could have a bad wire from the main harness on the car. But it runs straight into the big wiring harness and who knows where to look after that
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
