knochgoon24
DSM Wiseman
- 6,135
- 98
- Jan 29, 2008
Troy,
Michigan
I just got new SS studs from ssstuds.com. In the package, they included flat washers and split washers.
Now, if I understand correctly, split washers work by biting into two surfaces and prevents them from counter-rotating.
Here's my question: I can't see how you could use a flat washer AND a split washer on the same stud. Wouldn't you want the split washer between the flange and the nut? If you put a flat washer in there somewhere, it would spin?
So should I do,
Nut
Split Washer
Flange
or some other combo?
And what color Loctite do you use to hold the studs in the head and the nuts on the studs? I used blue last time on OEM studs and copper nuts, but those came loose. Most of the studs screwed out before the nuts came off the studs.
So should I do,
Nut
Split Washer
Flange
