[RESOLVED] Profec, EBC vacuum line spot (bov?) where
ApexVIII
812
5
Jan 12, 2008
Modesto, California
soon i am going to install my 16g, but it does not have a nipple like the T25 does, where can i tap in to for this?
the greddy manual says it wants it to be off the turbo so it always has pressure,
but i cant do that so can i just run it off the BOV line?
:dsm:
You would tap the same place you would for an MBC, which is on the intercooler piping or the compressor housing. You'll have to drill your LICP/J-pipe and tap it for a barbed fitting.
Do NOT use your BOV line.
where can i get a barbed fitting that will thread in to the part right befor the J pipe? i cant find one that small
Go to any auto parts store. Ask for a 1/4" or 1/8" NPT brass barbed fitting with a male threaded end. You'll have to drill a hole through your J-pipe, then run the appropriate sized tap through the hole so you can screw the fitting in. You can use Teflon tape to seal it, or you can go gung-ho and use JB Weld to REALLY seal it.
GOT Blitz DSBC and I hooked it after TB( I wanna regulate pressure which is after TB..and it worked well..Now I got External gate Tial 44..and found drawing in DSBC manual I have to TAP it from Compressor housing for lower port of Tial and for upper Tial port Tap from UICP ..then to the DSBC solenoid..and to the upper Tial port.
May I use boost source after TB???? ..
Thanks
