bboyalan
- 438
- 2
- Feb 5, 2008
Chula Vista (San Diego),
California
Hey guys! I've been trying to fix this w/ my dad since Friday night, but I must resort to asking for help now as it is simply too time consuming w/ college and all...
Long story somewhat shorter [so I can explain the current situation]:
-A'PEXi dp + high flow cat installed friday noontime [nice, powerful drive home]
-installed boost/vac gauge on that friday afternoon [easy source taps]
-tried drilling through passenger footwell w/o looking
-ended up going through steering wheel boot [success!]
-key in ignition = no go for instrument cluster
-car would crank, but not start
-ends up I drilled through the wires behind and beneath the battery...
-reconnected and wrapped up wires
-car cranks, starts, but has terribly low, bogging idle [200RPM near death]
-smells like unburnt gas [not enough air in mixture for combustion?]
-checked plugs and wires
-replaced 1-month old NGK G-power platinums [toasted] w/ *new* NGK iridiums
-did the throttle SAS + BISS adjustment properly to help idle @ 400-500 RPM
-test drove and had POOR acceleration + threw p0300 code for random misfire
-erased code & grounded the brown plug for ignition timing adjustment
-boost and vac leak check
-test drove again w/ the same poor acceleration, P0300 code, but <400RPM now
SO NOW [and I apologize for the brief summary] I'm here w/ some diagnostics/results and hoping to get some good direction and recommendations
. We pulled the plugs out after the code was thrown to see if any weren't firing and they all checked out okay. I also tested the ISC [Idle Speed Control] and came up with 41 Ohms on each [supposed to be 28-33]. In addition, I tested both the primary and secondaries of my coil pack. The secondary checks out within proper range, BUT the primaries were showing 11.2 for each [should be 0.70 - 0.86]. My NGK wires are 1-month old and have good resistance in them.
What should I be testing for or replacing next? I have such a terrible headache from thinking about this on the constant and I've devoted practically ALL of my study time towards searching the forum + trying out new things. If there is any other information that's needed, then I'll try my best to provide them. Any help is appreciated!
ps: this thread seems to have a similar problem minus the first half of b.s. I had went through.
. We pulled the plugs out after the code was thrown to see if any weren't firing and they all checked out okay. I also tested the ISC [Idle Speed Control] and came up with 41 Ohms on each [supposed to be 28-33]. In addition, I tested both the primary and secondaries of my coil pack. The secondary checks out within proper range, BUT the primaries were showing 11.2 for each [should be 0.70 - 0.86]. My NGK wires are 1-month old and have good resistance in them.What should I be testing for or replacing next? I have such a terrible headache from thinking about this on the constant and I've devoted practically ALL of my study time towards searching the forum + trying out new things. If there is any other information that's needed, then I'll try my best to provide them. Any help is appreciated!
oh well, i've got an old truck that i can drive i guess until i get my gst going or buy something else for a work car.
], and covered the biss screw.
