turboAWDfanatic
- 347
- 35
- Aug 22, 2005
Colorado Springs,
Colorado
I'm trying to dial in my new 2.3 stroker so that it will safely run low boost levels before I start cranking it up. I'm running a boost source straight to the wastegate (all mods in profile are current).
Basically I hit 9psi pretty quickly and then it creeps to around 12psi. At about 5,500 it starts to lean out really bad, and my Knock and EGTs predictably shoot up. I've been successful at tuning the afr properly for low throttle settings and for high throttle settings (but only up to about 5,000rpm) with the AFC. I'm not hitting fuel cut (IPW and IDC says my 450cc injectors aren't maxed out yet). Even when I enrich the 5-7k rpm range a LOT with the AFC, I get the same results. One thing to note: my stock O2 sensor seems to be reading low, but my WBO2 shows perfectly fine mixture until 5,500. Look for a log w/ WBO2 below. Any ideas?
Here are some logs. Unfortunately I can't log everything at once, so I'm going to post three different logs of 3rd gear pulls, all done under similar conditions. I'll make separate posts for each log.
First log is from my ECU. I used the "Injector Duty Cycle = Pulse Width x RPM / 1200" equation to get IDC from IPW:
Code:
<html xmlns:o="urn:schemas-microsoft-com:office:office"
xmlns:x="urn:schemas-microsoft-com:office:excel"
xmlns="http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=Content-Type content="text/html; charset=windows-1252">
<meta name=ProgId content=Excel.Sheet>
<meta name=Generator content="Microsoft Excel 11">
<link rel=File-List href="08-02-22%20IDC%20Log_files/filelist.xml">
<style id="08-02-22 IDC_24415_Styles">
<!--table
{mso-displayed-decimal-separator:"\.";
mso-displayed-thousand-separator:"\,";}
.xl2224415
{padding-top:1px;
padding-right:1px;
padding-left:1px;
mso-ignore:padding;
color:windowtext;
font-size:10.0pt;
font-weight:400;
font-style:normal;
text-decoration:none;
font-family:Arial;
mso-generic-font-family:auto;
mso-font-charset:0;
mso-number-format:0;
text-align:right;
vertical-align:bottom;
mso-background-source:auto;
mso-pattern:auto;
white-space:nowrap;}
.xl2324415
{padding-top:1px;
padding-right:1px;
padding-left:1px;
mso-ignore:padding;
color:windowtext;
font-size:10.0pt;
font-weight:400;
font-style:normal;
font-family:Arial;
mso-font-charset:0;
text-align:general;
mso-pattern:auto;
.xl2424415
{padding-top:1px;
padding-right:1px;
padding-left:1px;
mso-ignore:padding;
color:windowtext;
font-size:10.0pt;
font-weight:400;
font-style:normal;
font-family:Arial;
mso-font-charset:0;
mso-number-format:Fixed;
text-align:right;
mso-pattern:auto;
.xl2524415
{padding-top:1px;
padding-right:1px;
padding-left:1px;
mso-ignore:padding;
color:windowtext;
font-size:10.0pt;
font-weight:400;
font-style:normal;
font-family:Arial;
mso-font-charset:0;
text-align:general;
mso-pattern:auto;
</style>
</head>
<body>
<!--[if !excel]> <![endif]-->
<!--The following information was generated by Microsoft Office Excel's Publish
as Web Page wizard.-->
<!--If the same item is republished from Excel, all information between the DIV
tags will be replaced.-->
<!--START OF OUTPUT FROM EXCEL PUBLISH AS WEB PAGE WIZARD -->
<div id="08-02-22 IDC_24415" align=center x:publishsource="Excel">
<table x:str border=0 cellpadding=0 cellspacing=0 width=302 style='border-collapse:
collapse;table-layout:fixed;width:228pt'>
<col class=xl2324415 width=56 style='mso-width-source:userset;mso-width-alt:
2048;width:42pt'>
<col class=xl2524415 width=62 style='mso-width-source:userset;mso-width-alt:
2267;width:47pt'>
<col class=xl2524415 width=61 style='mso-width-source:userset;mso-width-alt:
2230;width:46pt'>
<col class=xl2324415 width=53 style='mso-width-source:userset;mso-width-alt:
1938;width:40pt'>
<col class=xl2524415 width=70 style='mso-width-source:userset;mso-width-alt:
2560;width:53pt'>
<tr height=17 style='height:12.75pt'>
<td height=17 class=xl2224415 width=56 style='height:12.75pt;width:42pt'>(RPM)</td>
<td class=xl2424415 width=62 style='width:47pt'>IPW (ms)</td>
<td class=xl2424415 width=61 style='width:46pt'>O2 (V)</td>
<td class=xl2224415 width=53 style='width:40pt'>TPS (%)</td>
<td class=xl2424415 width=70 style='width:53pt'>IDC</td>
</tr>
<td height=17 class=xl2324415 align=right style='height:12.75pt' x:num>4000</td>
<td class=xl2524415 align=right x:num>5.89</td>
<td class=xl2524415 align=right x:num>0.80</td>
<td class=xl2324415 align=right x:num="32.55">33</td>
<td class=xl2524415 align=right x:num="19.633333333333333"
x:fmla="=(B2*A2)/1200">19.63</td>
</tr>
x:num="4031.25">4031</td>
<td class=xl2524415 align=right x:num>6.14</td>
<td class=xl2524415 align=right x:num>0.78</td>
<td class=xl2324415 align=right x:num="33.33">33</td>
<td class=xl2524415 align=right x:num="20.626562499999999"
x:fmla="=(B3*A3)/1200">20.63</td>
</tr>
x:num="3968.75">3969</td>
<td class=xl2524415 align=right x:num>6.40</td>
<td class=xl2524415 align=right x:num>0.82</td>
<td class=xl2324415 align=right x:num="33.73">34</td>
<td class=xl2524415 align=right x:num="21.166666666666668"
x:fmla="=(B4*A4)/1200">21.17</td>
</tr>
x:num="4062.5">4063</td>
<td class=xl2524415 align=right x:num>6.91</td>
<td class=xl2324415 align=right x:num="35.29">35</td>
<td class=xl2524415 align=right x:num="23.393229166666668"
x:fmla="=(B5*A5)/1200">23.39</td>
</tr>
<td class=xl2524415 align=right x:num>7.94</td>
<td class=xl2324415 align=right x:num="36.86">37</td>
<td class=xl2524415 align=right x:num="26.880208333333332"
x:fmla="=(B6*A6)/1200">26.88</td>
</tr>
x:num="4187.5">4188</td>
<td class=xl2524415 align=right x:num>8.96</td>
<td class=xl2524415 align=right x:num>0.84</td>
<td class=xl2324415 align=right x:num="37.65">38</td>
<td class=xl2524415 align=right x:num="31.266666666666666"
x:fmla="=(B7*A7)/1200">31.27</td>
</tr>
x:num="4093.75">4094</td>
<td class=xl2524415 align=right x:num>9.73</td>
<td class=xl2324415 align=right x:num="38.43">38</td>
<td class=xl2524415 align=right x:num="33.193489583333331"
x:fmla="=(B8*A8)/1200">33.19</td>
</tr>
<td class=xl2524415 align=right x:num>10.24</td>
<td class=xl2324415 align=right x:num="39.61">40</td>
<td class=xl2524415 align=right x:num="34.93333333333333"
x:fmla="=(B9*A9)/1200">34.93</td>
</tr>
x:num="4156.25">4156</td>
<td class=xl2524415 align=right x:num>11.26</td>
<td class=xl2324415 align=right x:num>40</td>
<td class=xl2524415 align=right x:num="38.999479166666667"
x:fmla="=(B10*A10)/1200">39.00</td>
</tr>
<td class=xl2524415 align=right x:num>11.78</td>
<td class=xl2324415 align=right x:num="41.57">42</td>
<td class=xl2524415 align=right x:num="40.80052083333333"
x:fmla="=(B11*A11)/1200">40.80</td>
</tr>
<td class=xl2524415 align=right x:num>12.80</td>
<td class=xl2324415 align=right x:num="43.14">43</td>
<td class=xl2524415 align=right x:num="44.666666666666664"
x:fmla="=(B12*A12)/1200">44.67</td>
</tr>
x:num="4343.75">4344</td>
<td class=xl2524415 align=right x:num>13.57</td>
<td class=xl2324415 align=right x:num="44.71">45</td>
<td class=xl2524415 align=right x:num="49.120572916666667"
x:fmla="=(B13*A13)/1200">49.12</td>
</tr>
<td class=xl2524415 align=right x:num>14.34</td>
<td class=xl2324415 align=right x:num="48.24">48</td>
<td class=xl2524415 align=right x:num="51.907812499999999"
x:fmla="=(B14*A14)/1200">51.91</td>
</tr>
x:num="4468.75">4469</td>
<td class=xl2524415 align=right x:num>15.36</td>
<td class=xl2324415 align=right x:num="54.12">54</td>
<td class=xl2524415 align=right x:num x:fmla="=(B15*A15)/1200">57.20</td>
</tr>
x:num="4406.25">4406</td>
<td class=xl2524415 align=right x:num>17.15</td>
<td class=xl2324415 align=right x:num="72.94">73</td>
<td class=xl2524415 align=right x:num="62.97265625" x:fmla="=(B16*A16)/1200">62.97</td>
</tr>
x:num="4531.25">4531</td>
<td class=xl2524415 align=right x:num>18.43</td>
<td class=xl2324415 align=right x:num="83.14">83</td>
<td class=xl2524415 align=right x:num="69.592447916666671"
x:fmla="=(B17*A17)/1200">69.59</td>
</tr>
x:num="4593.75">4594</td>
<td class=xl2524415 align=right x:num>19.20</td>
<td class=xl2324415 align=right x:num="87.06">87</td>
<td class=xl2524415 align=right x:num x:fmla="=(B18*A18)/1200">73.50</td>
</tr>
x:num="4562.5">4563</td>
<td class=xl2324415 align=right x:num="89.8">90</td>
<td class=xl2524415 align=right x:num x:fmla="=(B19*A19)/1200">73.00</td>
</tr>
x:num="4781.25">4781</td>
<td class=xl2524415 align=right x:num>19.46</td>
<td class=xl2324415 align=right x:num="92.16">92</td>
<td class=xl2524415 align=right x:num="77.535937500000003"
x:fmla="=(B20*A20)/1200">77.54</td>
</tr>
x:num="4937.5">4938</td>
<td class=xl2524415 align=right x:num>19.97</td>
<td class=xl2324415 align=right x:num="94.12">94</td>
<td class=xl2524415 align=right x:num="82.168229166666663"
x:fmla="=(B21*A21)/1200">82.17</td>
</tr>
x:num="4906.25">4906</td>
<td class=xl2324415 align=right x:num="94.9">95</td>
<td class=xl2524415 align=right x:num="79.56302083333334"
x:fmla="=(B22*A22)/1200">79.56</td>
</tr>
<td class=xl2524415 align=right x:num>20.22</td>
<td class=xl2324415 align=right x:num="95.29">95</td>
<td class=xl2524415 align=right x:num="82.670312499999994"
x:fmla="=(B23*A23)/1200">82.67</td>
</tr>
x:num="5062.5">5063</td>
<td class=xl2524415 align=right x:num>18.94</td>
<td class=xl2324415 align=right x:num="96.86">97</td>
<td class=xl2524415 align=right x:num="79.903125000000003"
x:fmla="=(B24*A24)/1200">79.90</td>
</tr>
x:num="5156.25">5156</td>
<td class=xl2324415 align=right x:num="98.43">98</td>
<td class=xl2524415 align=right x:num="81.3828125" x:fmla="=(B25*A25)/1200">81.38</td>
</tr>
x:num="5218.75">5219</td>
<td class=xl2324415 align=right x:num="99.61">100</td>
<td class=xl2524415 align=right x:num="80.151302083333334"
x:fmla="=(B26*A26)/1200">80.15</td>
</tr>
x:num="5437.5">5438</td>
<td class=xl2524415 align=right x:num>17.66</td>
<td class=xl2324415 align=right x:num>100</td>
<td class=xl2524415 align=right x:num="80.021874999999994"
x:fmla="=(B27*A27)/1200">80.02</td>
</tr>
<td class=xl2524415 align=right x:num="77.7109375" x:fmla="=(B28*A28)/1200">77.71</td>
</tr>
<td class=xl2524415 align=right x:num>16.90</td>
<td class=xl2524415 align=right x:num="76.578125" x:fmla="=(B29*A29)/1200">76.58</td>
</tr>
x:num="5468.75">5469</td>
<td class=xl2524415 align=right x:num>16.64</td>
<td class=xl2524415 align=right x:num="75.833333333333329"
x:fmla="=(B30*A30)/1200">75.83</td>
</tr>
<td height=17 class=xl2324415 align=right style='height:12.75pt' x:num>5625</td>
<td class=xl2524415 align=right x:num>15.87</td>
<td class=xl2524415 align=right x:num="74.390625" x:fmla="=(B31*A31)/1200">74.39</td>
</tr>
<td class=xl2524415 align=right x:num x:fmla="=(B32*A32)/1200">78.00</td>
</tr>
x:num="5687.5">5688</td>
<td class=xl2524415 align=right x:num>16.13</td>
<td class=xl2524415 align=right x:num="76.449479166666663"
x:fmla="=(B33*A33)/1200">76.45</td>
</tr>
x:num="5843.75">5844</td>
<td class=xl2524415 align=right x:num="77.283593749999994"
x:fmla="=(B34*A34)/1200">77.28</td>
</tr>
<td height=17 class=xl2324415 align=right style='height:12.75pt' x:num>6000</td>
<td class=xl2524415 align=right x:num x:fmla="=(B35*A35)/1200">80.65</td>
</tr>
<td height=17 class=xl2324415 align=right style='height:12.75pt' x:num>6125</td>
<td class=xl2524415 align=right x:num>14.85</td>
<td class=xl2324415 align=right x:num="64.31">64</td>
<td class=xl2524415 align=right x:num="75.796875" x:fmla="=(B36*A36)/1200">75.80</td>
</tr>
x:num="6062.5">6063</td>
<td class=xl2524415 align=right x:num>10.75</td>
<td class=xl2324415 align=right x:num="15.29">15</td>
<td class=xl2524415 align=right x:num="54.309895833333336"
x:fmla="=(B37*A37)/1200">54.31</td>
</tr>
x:num="5718.75">5719</td>
<td class=xl2524415 align=right x:num>1.28</td>
<td class=xl2524415 align=right x:num>0.70</td>
<td class=xl2324415 align=right x:num="11.76">12</td>
<td class=xl2524415 align=right x:num x:fmla="=(B38*A38)/1200">6.10</td>
</tr>
x:num="5562.5">5563</td>
<td class=xl2524415 align=right x:num>1.79</td>
<td class=xl2524415 align=right x:num>0.88</td>
<td class=xl2324415 align=right x:num="11.37">11</td>
<td class=xl2524415 align=right x:num="8.2973958333333329"
x:fmla="=(B39*A39)/1200">8.30</td>
</tr>
x:num="5531.25">5531</td>
<td class=xl2524415 align=right x:num="8.2507812499999993"
x:fmla="=(B40*A40)/1200">8.25</td>
</tr>
<td class=xl2324415 align=right x:num="10.98">11</td>
<td class=xl2524415 align=right x:num="5.5666666666666664"
x:fmla="=(B41*A41)/1200">5.57</td>
</tr>
x:num="4968.75">4969</td>
<td class=xl2524415 align=right x:num>0.68</td>
<td class=xl2524415 align=right x:num x:fmla="=(B42*A42)/1200">5.30</td>
</tr>
x:num="4718.75">4719</td>
<td class=xl2524415 align=right x:num>0.66</td>
<td class=xl2524415 align=right x:num="5.0333333333333332"
x:fmla="=(B43*A43)/1200">5.03</td>
</tr>
<td height=17 class=xl2324415 align=right style='height:12.75pt' x:num>4500</td>
<td class=xl2524415 align=right x:num x:fmla="=(B44*A44)/1200">4.80</td>
</tr>
<![if supportMisalignedColumns]>
<tr height=0 style='display:none'>
<td width=56 style='width:42pt'></td>
<td width=62 style='width:47pt'></td>
<td width=61 style='width:46pt'></td>
<td width=53 style='width:40pt'></td>
<td width=70 style='width:53pt'></td>
</tr>
<![endif]>
</table>
</div>
<!--END OF OUTPUT FROM EXCEL PUBLISH AS WEB PAGE WIZARD-->
</body>
</html>
I've got the 660's sitting on a shelf. Problem is I want to switch to 2g maf at the same time to bring the timing closer to where it should be (subtract for 660's, add for 2g maff). I can't fit the dang 2g maf yet b/c my huge upper IC pipe sits right where the 2g maf wants to go. What I might do is hack the 1g maf to send some more unmetered air through and keep an eye on my timing.
The Zeitronix has actually proven to be a great tuning tool over and over, and its done well in other shootouts. Actually, taking what I've posted here in context, my WB has been THE sure thing that is telling me where I'm at. The logs show that the Zeitronix is being perfectly consistent with what my engine is doing.
, glad you figured it out. You'll be happy when you start cranking up the boost!
