[RESOLVED] help with hids
The little red plug on the Shap HID kit is where you plug in the little tab that powered your factory low-beam bulb. The little black plug is where you plug in the little tab that grounded out your factory low-beam bulb. Look around a little and you should find the little tab by where your bulb sits. Unplug the tab and plug it into the black plug on the HID kit.
I also got mine from SharpHID.com, if they haven't changed it, 2g cars are reverse polarity so you have to cut the wires and solder them.
