[RESOLVED] Anti-Lock Brakes on GS?
Sounds pretty expensive. I doubt it would be worth the money unless you had a junked-out 2g w/ abs to move it over from.
Yes it does come on some eclipse's. But to swap it would be a pain as you will need a new wire harness and the abs unit. Wheel speed sensors and new abs hub bearings. And you will need the abs controller. along with a ton or new break lines to reroute the lines to the abs unit.
