[RESOLVED] Accessory belt woes
chetvram
87
May 22, 2006
Corvallis, Oregon
My belt that runs on the outside of the pulleys keeps popping off. I ajusted it with the tensioner off of the alternator and ot it tighter than the one that runs on the inside but it still keeps popping off. The belt is not broken just keeps popping off.
Same thing happened to my car and it turned out that my crank pulley split in two where the dampener(rubber part) is. Bought a new crank pulley and belt b/c mine were fubar. Problem solved.:thumb:
ya i loosened the pivot bolt. How common is for a belt to stretch? I'll have to check that pulley to see if it split.
Did you re-tighten the pivot bolt after the adjustment?
From my experience a new belt may stretch a tiny bit after a few hundred miles but not enough to cause it to come off of the pulley.
Did you remove any of the pulleys recently? Make sure that the alt pulley is not on backwards as this may cause misalignment of the belt.
Started up my car this morning and the belt popped off as it was cranking over. Reached down to put it back on from the bottem and found out the crank pulley had split into two pieces. Thanks for the help guys.
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
