[RESOLVED] 1g in a 2g adjusting TPS
jake247
102
Jul 25, 2007
Allentown, Pennsylvania
I am lost on this TPS thing. I thought I'd be able to set it to "0%" using pocket logger on my '99, but then a friend said that it has to be done based off of a voltmeter or snap on tool (and then he said something about me still not having dsmlink...
Anyway, finishing up my 2g swap, it's a 1g throttle body, with the 2g TPS sensor bolted on it.
Can I adjust it with my palm-pocket logger? If not, then how?
Thanks
:notgood: -- that bottom screw. what a p.i.t.a.
Log the tps voltage on your logger.. Set the tps but loosing it and turning it. With throttle closed it should be around .5 volts.. With the gas wide open it should read about 5volts.
I have Pocketlogger and it only tells me my throttle position in a percentage number. I looked through, including trying to log, but couldn't find a way to have it display a voltage.
I don't know if I'm missing something here or what.
The way I had it set up, being the wrong way according to my friend, right now, it goes past zero when I get on the gas, but only goes up to 95%.
Am I doing something wrong with my logger, or is this simply the wrong tool? Is there another way of doing this?
Turn it so it goes to 0, but make sure it read 1% when you barely press the peddle, and at WOT, anything over 90% is fine.
thanks rich. we'll have to meet up for lunch or something sometime.
sorry Burnett, you're too far, and gas is too expensive.
  • Wanted 6 bolt NT water pipe
    • chrisman287
