resistor pack bad???
ross41
61
Mar 4, 2003
n/a, Michigan
My car died on the highway. Felt like fuel cut but the walbro was still whirring. I've got spark, full battery, fuel pump whizzes and fuel comes out the return line of the fuel rail. It cranks, but doesn't fire. Do you think it's the resistor pack or the ECU? How could I test the resistor pack?
Ah, measure the resistance of each of the resistors? You can also look for battery voltage at the ECU on each of the injector pins for a quick test. That doesn't tell you if a resistor is out of spec but it will catch most problems with that circuit.
Have you checked the compression?
Steve
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
