Request : Engine bay measurements.
CanadianTalonTC
582
97
Jul 8, 2011
Lethbridge, AB, Canada
Hey guys,
Really didn't know where to post this, but was wondering fi somebody could get me the following measurements on this photo as accurately as possible.
Basically the amount of room between the engine and the strut tower at the smallest point, how far from the firewall the IM sits and how far you have to the intake tract. Along with depth to the trans from the height of the strut tower if possible.
Figuring out what size of W/A IC to put in there and need a good idea of size but my engine is beside my car :).
Thanks guys!
Joel
You can cheat and measure the width of say, your valve cover. Then use the picture and size it to an easy size that can be say 1/10th scale. Some easy math and you got your measurements using you own picture and your brain power. ;)
But otherwise i'm sure someone has these measurements already.
Why not just measure it yourself? seems the easiest way to me, plus you know what you want instead of relying on someone elses answer
Many different reasons. He could be away from his car. He could have the engine out, (most likely this reason). Im sure he knows thats an option.
Thanks for your suggestions guys but between angles of photos and the fact that my engine is beside my car as stated in the first post, I figured I'd see if someone could quickly grab a tape and a piece of paper.
I agree with your statement of relying on someone else but I'm basically trying to see if my planned setup is remotely feasible or if I'm totally out to lunch. Cause if I am I need to get back to the drawing board.
