Replacing Tranny/Clutch, check my order + recommendations
grimery
Nov 28, 2009
Price, Utah
I purchased a 95 Talon TSI AWD M/T awhile back knowing that it needed some work.
Goal:
350-400AWHP as reliable as can be
80% street driving (0-40 MPH), 20% highway (cruising @ 70MPH)
So far:
6 bolt motor B/S Removed
AC and Emissions removed
Fluidyne Radiator
3" offroad turboback exhaust
20G w/external wastegate
FIC 1050
Walbro 255
AFPR set to 43.5 PSI
DSMLink V2
PLX Wideband
Problem:
Every gear except first gear will engage (put into 1st, grinds when clutch let out)
I live in a small town in Utah, there are really no performance shops close by, however I finally found a shop that knew what a 6 bolt 4G63 swap meant.
What I've had them do so far:
Compression/leakdown test
Timing belt/pulley replacements
Set base timing 5 BTDC
Water pump
I am paying them labor to replace the transmission/clutch/other parts that I give them.
Currently I am looking at either the economy ($700) transmission swap from TRE or their $1050 build, input on this would be appreciated, from what I've read either one will hold up to 400 HP, I am debating if the extra $350 is worth it for my goals.
I need recommendations on a clutch.
Currently I've been looking at the ACT 2600 + Fidanza flywheel combo, but have been reading good things about the Fidanza 3.2 Kevlar as well as the Fidanza 4.3.
I am not too concerned with the clutch pedal feel being luxurious, my last three vehicles have been an 04 Turbo GTO, 06 GTO, and 01 WS6 (all M6) and I have never had a complaint about the clutch, though I am not sure the actual difference between the feel of those stock clutches compared with a performance DSM clutch.
At the same time of the transmission swap I am going to have them replace the clutch and other parts that I can think of.
I believe I've ordered everything needed for this besides the actual clutch kit/flywheel, please check my list and make recommendations:
OEM Clutch Master Cylinder Assembly : Mitsubishi Eclipse 95-99
OEM Clutch Slave Cylinder Assembly : Mitsubishi Eclipse 95-99
OEM Clutch Pivot Ball : Mitsubishi Eclipse 90-99
Extreme PSI Complete Clutch Line (Slave to Master Cyl.): Mitsubishi
OEM Gear Shift Cable: Mitsubishi Eclipse 95-99
OEM Clutch Release Fork : Mitsubishi Eclipse 90-99
Slave Cylinder Extension Rod : Mitsubishi Eclipse 90-99
New Engine/Starter Plate 4G63 Turbo 6 Bolt M/T
Thanks for the feedback,
WS6 and shit is WAYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY WAYYYYYYYYYYYYYYYYYY easier to drive than even an ACT 2100 LOL. v8's dont use stiff pressure plates most of the time unless its aftermarket.
I have been happy with my Fidanza 4.3 with fid flywheel, have around 2000 miles on it so far. I don't currently have a very aggressive setup tho, just a small 16g. Fidanza recommends any AWD car go with their 4.3 and not the 3.2 .
Ended up going with an ACT 2600 + Performance Street Disc and an ACT Streetlite chromoly flywheel. TRE Stage 1.5 Transmission w/ 4 spider center diff and Ripgrip front is on the way, hopefully will suit my needs.
i
Thanks for the replies
I was curious on how well that tre base tranny held up because I am in college right now and on a extremely limited budget now and I am in dire need of a new tranny very soon.
