replacing lower front control arm and ball joint
From the Haynes manual:
Shock absorber
Upper mounting nuts - 44
Lower mounting bolt to damper fork - 65 to 87
Damper rod nut - 14 to 18
Damper fork to lateral arm bolt/nut - 65
Stabilizer bar
Bracket bolts - 28
Link nuts - 28
Compression lower arm:
pivot nut - 65
balljoint - 43 to 52.
Lateral lower arm:
damper fork bolt - 65
mounting bolts - 60
You know that there was a recall on the lower control arm for our cars right? If you've never replaced them you can have a dealer replace them for free.
http://www.2gnt.com/nuke/modules.php?name=Sections&op=viewarticle&artid=13
