ball joint
RoasT BeeF said:
Put a jack under it.
I'm with stupid ^^^^
Apply as much weight to the knuckle/suspension as possible. Maybe even put a 2x4/4x4 between the upper ball joint and the inner fender (not the fender itself) to help load the suspension. It will eventually create enough force to seat the ball joint in to the knuckle so you can tighten it with the suspension still loaded.
Doug
  • Wanted 6 bolt NT water pipe
    • chrisman287
