replacing front o2 with WB
gixrman
1,997
17
Nov 13, 2002
Frederick, Maryland
I'm installing my innovate WB in my front o2 spot (replacing the OEM o2)and want to make sure I see the correct signal in the front o2. Its the brown wire from the guage that replaces the front o2 input going into the ECU correct? Which is the white wire pin#75
This is from Innovates install instructions and this is what I'm confussed about the yellow or brown. So analog output 1 is correct?
Optionally, the YELLOW (Analog out 1) and/or BROWN (Analog out 2) can be connected
to the analog inputs of other devices such as data loggers, ECUs, or gauges. If either one or
both of these wires are not being used isolate and tape the wire(s) out of the way. The default
analog outputs are as follows: Analog output one is 1.1V = 14 AFR and .1V = 15 AFR. This is
a simulated narrowband signal. Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39
AFR.
