1. Join the Community!
Removing the valve cover to change new gasket
Posted by TSiRocker, May 5, 2005
Please Support Feal Suspension
  1. TSiRocker
    TSiRocker Proven Member
    56
    Joined Dec 6, 2004
    Texas, Central America
    I am stuck with the valve cover as it's PITA to ply off the cover. It just won't budge!
    Will it be safe to use cutting knife to shred off the rubber gasket to free up the gap for easy removal?
  2. igopoopy
    igopoopy Proven Member
    1,094
    7
    Joined May 5, 2004
    tucson, Arizona
  3. mysticfire6602
    mysticfire6602 Proven Member
    372
    6
    Joined Dec 23, 2004
    Bloomsburg, Pennsylvania
    that should be fine. i used a flat head screwdriver and hammered it in there to pry mine out.
  4. TSiRocker
    56
    Joined Dec 6, 2004
    yes, I have all the bolts off the cover.
    I will try the hammering idea if mine doesn't work :)
    Okay, once I get the cover off.
    How do I apply the RTV? Do I apply on both sides, the valve cover and the engine block?
  5. igopoopy
    1,094
    7
    Joined May 5, 2004
    tucson, Arizona
    Use a SMALL amount of RTV sealant on valve cover side with the spark plug seals and main valve cover gasket
    Use RTV sealant on semi-circular plug and the 2 camshaft and crank angle sensor humps (see illustration)
  6. TSiRocker
    56
    Joined Dec 6, 2004
    I can see you are emphasizing on the SMALL amount of RTV. Any reason why?
    What will happen if I apply too much RTV on it? Will it gets stuck like a glue?
  7. mysticfire6602
    372
    6
    Joined Dec 23, 2004
    just imagine a hunk of goop falling onto your valves...
    personally i didnt use any RTV when i replaced mine.
  8. TSiRocker
    56
    Joined Dec 6, 2004
    Ah..ok, i will get the gaskets up tonight.
    Thanks for the quick reply from you guys!
    I hope there will be no more annoying leaks after the change...
  9. Defiant
    Defiant DSM Wiseman
    25,196
    148
    Joined Jan 13, 2003
    glorious Galt, California
    Oh, there will be. :toobad:
    3K  0
    1995 Eagle Talon TSi AWD
    manual · 2G DSM
    Loading...
  10. Omega
    Omega Proven Member
    1,275
    10
    Joined Oct 10, 2002
    Randolph, New Jersey
    :mad: Tell me about it. The second time it went on I think it has sealed well enough. Nothing more scary than plumes of smoke coming out the front of the car because oil is dripping in the heat sheild.
  11. Mack
    Mack Proven Member
    169
    Joined May 7, 2003
    Cleveland, Ohio
    A loving tap from a rubber mallet showed my cover who was boss.
  12. TSiRocker
    56
    Joined Dec 6, 2004
    Amazingly, the process went pretty well.
    Applied RTV all around the rubber gasket and the spark plug gaskets, let it dry off for 10minutes and test drive it for 30minutes and voila! NO LEAKS!!!
    I don't see why you guys still having leaks after replacing...
  13. Defiant
    Defiant DSM Wiseman
    25,196
    148
    Joined Jan 13, 2003
    You will. :|
    3K  0
    manual · 2G DSM
    Loading...
  14. MDAdams1186
    MDAdams1186 Proven Member
    39
    Joined Nov 16, 2004
    Churchville, New York
    Hey Defiant howcome there will be leaks afterwards no matter what? I am discouraged to replace mine now if it won't fix it:(
  15. Defiant
    Defiant DSM Wiseman
    25,196
    148
    Joined Jan 13, 2003
    It's a Mitsubishi. They just leak. Oh, sure, there are fifty out there that don't, but they don't count. Mine does, and we can't even figure out where from. I just feed it.
    3K  0
    manual · 2G DSM
    Loading...
  16. MDAdams1186
    39
    Joined Nov 16, 2004
    ahh well that certainly sucks...but I guess no biggy if it's not effecting anything.
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
