Removing Rear Trim Panel
HAZ0R
Feb 6, 2008
Gulfport, Mississippi
How doyou remove the rear trim panels in the hatch area, not the panels on the hatch below it...
Yeah, in the trunk area. The panel in the center at the back... Between the panels that house the tail lights.
Just pull on them. The christmas tree plugs will pop right out. There are 4 (if I remember right) that go across the top that have to be pulled up. So, pull the bottom part of the panel FORWARD, then pop the whole panel UP once the vertical part is clear.
