1G Removing 3 Bolt Rear Differential
sleeper1ga
160
14
Oct 4, 2014
Chicago, Illinois
I have a 90 with 3 bolt differential, I'm looking to swap differentials to an auto differential. I believe I know how to do the swap, but would like to know how from someone else who has done it(for I don't end up confused halfway). Any help is appreciated!
Thanks, Sleeper1ga
If they are both 3 bolts Just change the center diff. If you're going to a 4 bolt then you'll need to swap everything over. If your rear is healthy then I would say swap the ring an pinion and while you're at it properly shim it and make sure they are contacting in the right area on the pinion gear. Also a great time to put in new bearings and seals for peace of mind.
