removed solenoids, what to block?
coupe_nasty
266
16
Oct 15, 2011
Easton, Maryland
So i removed my egr, evap, and fuel pressure solenoids near the firewall. Now im wondering if i am correct in that i need to block off P E and A on the intake manifold. And also, what about the curved hard pipes that run down behind the intake manifold? do they need to be blocked or just removed? Im assuming they go to the charcoal canister under the battery? Although one seems to tap into the intake manifold down lower underneath. Just dont want any boost leaks.
Those 2 curved limes are for your egr so no you dont need to cap them as you removed the egr
make it look better and remove them lines anyway as you no longer need them
