relieving the fuel system
gstowner
246
Nov 13, 2004
Creston, Iowa
HI,
I was trying to relieve the fuel system. Unplugged the pump let it run for 10 minutes or so and it still hasn't died. How long does it take? is something wrong?
thanks
If you're following the manual the picture they have is misleading as to which plate to remove from under the passenger seat to get to the fuel pump connector.
Look to the left of the middle plate you removed and find another similar looking metal plate. Remove this one and unplug the connector for the fuel pump. Start the car up and it should die within a few seconds (be sure the fuel cap is off when you do this).
Do what you need with the fuel system then plug everything back in and fasten down both metal plates.
