reinstalled air conditioning a/c
greathuskie
2,666
4
Sep 10, 2002
Hollywood, Florida
so a long time ago i took the AC off my car, lines and all, and now i want to reinstall it because im a dumbass. any instructions or places where i can find how to do this, and is it gonna be a real bi*** to do or just basic reinstall the parts?
Grab yourself a hayne's manual at your local autozone or autoparts store and use it as a guide. Every dsm'er should have one.
If you kept all of the parts, and removed them with car (or you can find good used or new parts) it should be relatively an easy task. However, once you get it all done, you will need to use a vacuum pump to suck a vacuum into the system, and have it charged. Couple of words of advice. Change ALL of the seals, and convert it to R-134A.
im moving to florida soon i think and i need to get on this in the next 2 months. i plan on buying a full AC system (lines and all) and will hopefully get it installed, is it going to be possible to install all the AC lines and everything else without significant moving or removing of other parts that may be in the wy?
