Air Conditioning Help
dsm144
112
Jun 7, 2011
Conover, North Carolina
So im working on my gst and im wondering if there is any way to get the ac back. I have all of the ac components but the j pipe off of my turbo made me lose the air fan as you all know. My question tho is could I not just plug the ac cable into the other fan and use it? Will that cause any problems?
Idk about the 2g radiator fans but, if you unplug the one fan connector and use the A/C, your car will not turn on the fan when it gets a little hot, it will only turn on when you push in the A/C button. My car I believe the button was a transister, that provided a ground when pushed in, which then grounded the relays coil, and caused the switched part of the relay to move down creating a connection for the cooling fan and A/c fan to both turn on.
They also sell aftermarket fan shrouds that work pretty well for cooling. The fan is there to keep you from over-heating when the A/C is on, so like the guy above me said, just pick up an aftermarket slim fan and go.
