Recommended Super AFC II Settings
2bclutch
203
Jan 10, 2006
Richardson, Texas
Okay so here's the set up. 190LPH Fuel Pump, 550cc Injectors, Big 16G EVO III Turbo. What kind of air/fuel correction settings should I have to be safe? I need to get to a dyno and get them properly set up but what would be safe settings? It allows you to go to -50 I'm running at about -28 to -30 at the mid range of the low and high RPM. Any input on what I should set the 500rpm increments at for the low and high RPM ranges would be very helpful. Any suggestions?
Yikes. Put your low throttle at -5 and your high at -10. And don't go to WOT. Your injectors are only 18% bigger, why would you want 30% less fuel?
edit: I take it you don't have a logger?
It depends on the car but roughly negative 10-15 on your high throttle and low could be left alone because the computer can change that some but it could be some negative you need to get a wideband O2 and logger or get it dynotuned shortly but that will give you a start. Good luck
weith you beat me to it o well.
For SAFE settings, let it run rich. Running rich is MUCH better than running lean. Running too lean may result in ruining your engine or turbo. Set it to maybe -10 correction and get a Datalogger at least. Best is to get these 3 things:
Data Logger
EGT gauge
Wideband O2 sensor (not needed but will really help)
Mine where in the high -20's with the S16G. I need to retune now that I got the Evo III. But you can't recommend settings, you NEED to dyno it. And stay off boost until then.
Okay I'll run it up in the 10-15 range then. Yes definately going to get it dynotuned, this is not a DD so no biggie, just don't want to mess up the engine driving it to the dyno. What exactly sets the WOT on the AFC? and wouldn't an air/fuel ratio gauge be better than an EGT?
