Recirculating with dejontool intake and greddy pipe?
greenmachine97
539
3
Jan 4, 2004
St. Charles, Missouri
Ok, i am one of those annoying venter kids, i like the sound;)
anyway, i dont vent by choice, i vent because i cant get my recirc. pipe to go on. literally, i have the greddy type-s BOV, greddy IC piping kit, and Dejontool intake hardpipe. do any of you have the same setup and successfully gotten a pipe on there. anyway, since i cant get my factory tube to fit, what are my other options? and where can i get a correct pipe to fit? thanks in advance.
NO tengo dinero!!! ( i have no money)
i plan on doing that eventually, hopefully. but for now, I WANT TO RECIRCULATE!!
Yes, I know spanish :thumb:
Probably go to a parts store and grab various pieces of bent radiator hose and exhaust pieces to fit inside and make your own tube. I have no idea other then that.
Is the tube that I circled the recirc part of the intake? If it is then it should be really easy to find a piece of radiator hose to fit.
yes, that is part of the intake. how heavy duty does the tubing need to be? but getting a piece to fit in there is harder than it looks. i couldnt get my stock one to fit:mad: , and now the idle has a mind of its own!
Any rubber hose should work, as long as you can it to seal. Just go check out the local parts store and tell them what you need.
well that is good news. i will try to get that done this week, thanks for the help. and doing this is suposed to cure my mysterious idle, correct?
Yes, it should help out there.
Also, did you buy your Greddy-S brand new? If so even though you are recirculating it the noise is still loud enough to hear. It sounds alot louder than you think it will. Mine sounds like it is vented and when I pop the hood and show people they all thought that it was venting to the atmosphere.
You'll be able to fit a hose on there easier, if you cut off a little bit of the metal pipe.
that is a great idea. i had not though about that yet! i will see. thanks for the help
