- Thread starter
- #101
KeelesKustome
- 882
- 17
- Dec 29, 2007
Waverly,
Tennessee
here is one for you. explain this, i don't have a voltage meter with me so i am using a test light.
the light is grounded, i touch the starter relay pin and turn the key forward and the light comes on, when i release the light goes off. working normally.
so then i go to the starter relay, the same thing, so it's working even though it isn't making a clicking sound.
so here i decide well lets check the fuel pump, i turn the key to acc, touch the wire and my light comes on, but here is the kicker, so does my fuel pump.
as long as i hold my test light to it it'll stay on, i let go and the fuel pump kicks off......i even here the relay click to work when i do so.. what in the heck does this mean?
neither 12 or 25 light the test light up
nothing on 71 as well
does that mean my relay in behind the radio is bad? i swapped it out twice.
my mhi relay does not have a constant 12v power supply for some reason when the key is not in the ignition.. why? my engine 20amp fuse isn't blown either, nor are any others that i can see.
my 91pin isn't black, it's black with a red stripe, and if i am looking at the wrong one.. by chance the other side is black with a white stripe
