Rear wheels cambered?
MrdB
52
Jun 28, 2004
Chillicothe, Ohio
ok, i have kyv agx struts all the way around with h&r spring... my rear wheels are sssoooo cambered its not even funny? do they make a camber kit? or will a sway bar fix it?
What do you mean your wheels are soooooo cambered?
Ingalls makes camber kits, SPC Performance does as well. If you click on any of the DSMTuner sponsors they should be able to get some sort of camber kit for you.
sheesh, there's about a million threads comparing 1g rear camber kits. Bottom line, if you don't need a huge amount of adjustment, you can get away with getting an eccentric bushing kit, such as DME's. http://www.dmotorsporte.com/ Much cheaper than Ingall's kit.
if you are going to buy a camber kit i'd look around or make your own. the ingalls kit will probably give you the most adjustment but they tend to snap. it happened to a friend of mine and his car was stranded for a while. the eccentric bushings are nice but dont' give you much adjustment. i'm going to try to make myown with some DOM tubing and some rod ends i'll let you know how they turn out
