Rear upper arms
2gdanny
625
17
Mar 9, 2007
south river, New Jersey
Hey guys this might be a question that it was covers befor but I can't seem to find it.
As I start bolting everything back on to the car, I came across the rear upper control arms bolts, the bolts that holds the control arm to the car.
I remember each bolt had about 5 washer each but im not 100% sure and also what order they go?
I'm not really aware of any washers being used in the mounting of stock rear upper arms. The washers sounds like a DIY camber kit, so only you can tell us how many you need, if that's what they're for.
As for the order, I'd put the washers on before tightening down the bolts:p
Not being a jerk, just messin' around. Can you give us a little more information?
Yeah it might have been done by the other owner, I'll be sure to take pics of where they go and where I took them from , I just can't remember how manny there where in each bolt.
So we're in agreement that this is for the rear camber?
Assuming that's the case, this is a simple fix. How many washers do you have? Divide that number by 8 and you'll have the correct number of washers to put under each mounting point.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
