Rear Tires Skipping on Turns (Auto)
97gst_spyder
2,262
16
Sep 1, 2008
Lakeland, Florida
This has been an issue since the AWD swap was done. Rear inside tire skips on any hard turns, at slow speeds. Checked everything, rear diff is not seized, pulled and swapped the center diff, nothing. The diff I pulled out and also replaced it with were both open! WTF can cause this? I have 4 brand new axles, 4 matching tires,
Also, after I installed the new diff the car acted perfect. I took about 3 sharp u-turns at full lock. No binding, car was great. After about 20 milles of city driving the issues were back.
Welded center diff can also cause some tire binding issues. Try street driving a welded center and rear end LOL... Has that trans ever been built? The welded center is atop the list for things to do for an auto.
Do your tranny, transfer case and rear diff all match? I had a similar issue and it turned out to be improper gearing. After busting my head for quite some time, I realized that the transfer case was causing the problem. I changed the transfer case to match the 96awd tranny I had and it took care of the skipping.
Stock 220k+ on the trans. Both center diffs were open, NOT welded. We thought the original one that came in the trans was welded by the symptoms. Swapped it same damn issues.
They all came from a matching car. All had the same 1/8in of rust etc.
Was yours an auto or manual?
center diff is not open. it has a viscous coupler attached to it. a viscous coupler is a clutch pack diff that is sealed in its own fluid.
so if viscous was locked car would act just like a welded center diff would. not saying that is what you problem is. just clarifying how the driveline works.
rear tire bark suggests rear diff is locked, or not turning smoothly
I was thinking about the VC, but after reading everything I can on how our drivetrain works, I'm stumped.
I checked the rear diff with the driveshaft locked in part, I can rotate one rear tire forward and the other side will go backward. Also, with the driveshaft free, I spin one, and the other goes the same direction as per how the LSD is suppose to work. As far as I know.
On both center diffs, the two inner splines rotate opposite of each other. So as far as I can tell with that also, VC is all thats left.
