Rear suspension problems. Please help.
untouchablecc
852
13
Mar 21, 2008
Mt. pleasant, Pennsylvania
I have been battleing some rear suspension issues. My car pulls to the right in the rear anytime im on a traction breaking surface such as snow or alot of rain. I just orderd new toe adjustment (bolts and trailing arm). I am one of the dsmers with the rear toe adjustments seized. Now my main concern is i just bought prothane bushings for the rear of the car because you can see that i have some camber issues. The rear wheels look like they are squating. Top of the tires being inward. I just replaced all the rear bushings except the lower two on the rear.
What could be cause this much negitave camber. There is no adjustment for camber an it was bad enough the shop didnt even try to align it because you can see its out and the toe is seized. Is it possible the shocks are on wrong? If so what could have been screwed up. I have tokico adjustable shocks in the rear for my car(illuminas to be exact). They are set on 3 of 5. I have stock springs my ride height proves it. I dunno what else it could be.
