Rear Strut Mount
Pro3racer
549
Nov 26, 2004
Stevens Pt./UW-Whitewater, Wisconsin
Can somebody help me out, i have own my car for quite a while, but just a month or so ago, noticed my right rear bottom strut mount bolt is missing. I decided to go buy a bolt(same as other side), but the bolt wouldn't thread in, so i took the other sides bolt out, and that bolt wouldn't thread either. I noticed light rust in the threads, but still, the sizes are just off. Any ideas? I want to install my AGX's, but since the stock strut is rust welded on, and not bolted on, taking it off without a bolt will leave me in a bad spot.
lift it off ground and try knocking it out or atleast loosening it up with a rubber mallet, and lube it up, but if you do lube it up I wouldnt drive it just because it could get loose while your driving.
  • Wanted 6 bolt NT water pipe
    • chrisman287
